  • February 23, 2020, 01:47:41 AM
Pages: [1] 2 3 4   Go Down
Author Topic: Look at me...  (Read 8770 times)
f1int7
Look at me...
« on: August 01, 2001, 04:06:00 PM »
Well, I worked hard to get my posts up to the high 78 posts I had. So this thread is for all you spammers out there who want their post counts and status back. Instead of clogging up every single thread, Clog this one up. Who says I don't contribute anything good?
[ This Message was edited by: f1int7 on 2001-08-01 17:07 ]
Look at me...
« Reply #1 on: August 01, 2001, 04:07:00 PM »
I said.
f1int7
Look at me...
« Reply #2 on: August 01, 2001, 04:07:00 PM »
bump?
f1int7
Look at me...
« Reply #3 on: August 01, 2001, 04:08:00 PM »
TTT
NMDante
  • Aaargh!
Look at me...
« Reply #4 on: August 01, 2001, 04:42:00 PM »
Is getting your post count that important???
Look at me...
« Reply #5 on: August 01, 2001, 05:20:00 PM »
YES!
NMDante
  • Aaargh!
Look at me...
« Reply #6 on: August 01, 2001, 10:20:00 PM »
Ok, ok, winterstick....you'll probably get your post count back up there in a few days.  :)
I really didn't care, but that's just me.  I usually came around to help and hear insane ideas for case mods, some of which I tried!  :P
Vortek
Look at me...
« Reply #7 on: August 02, 2001, 05:17:00 PM »
Just curious...which ones?
kid
Look at me...
« Reply #8 on: August 02, 2001, 09:44:00 PM »
Yea to bad it was the wronf formula that you used vortec for I wanted my computer to have one of those.. but its simpler eisery cheaper and quieter (sp?) to just gat a 120 mm fan
NMDante
  • Aaargh!
Look at me...
« Reply #9 on: August 02, 2001, 10:22:00 PM »
Which ones were insane, or that I thought were insane????
Well.....there wasn't too many totally insane ideas (ie. splashing water into the case creating a waterfall affect) but the one about using oil to help cooling was a bit of a reach, especially for a PC.  I gave my 2 cents, tho, since I use to work with oil encased components.
There were some funny ideas, but like I say....
If you can dream it, try it!!!
Pages: [1] 2 3 4   Go Up
Page created in 0.079 seconds with 34 queries.
