  • October 25, 2020, 10:51:44 PM
Author Topic: Quiet That Hyper 6 CPU Cooler  (Read 3318 times)
Grump
    • 1 Foot In The Grave
« on: June 20, 2004, 05:08:34 AM »
[click any image for a larger view]
Last year, Cooler Master introduced a massive CPU cooler based on new heatpipe technology, the Hyper 6. It's an impressive 2 pounds of copper and aluminum that towers above most other coolers. It seems to ignore both Intel and AMD specifications for weight, but it comes equipped with a replacement retention module and ingenious backplate to increase strength and stability. This muscle-bound HSF combo has bested the previous champions of CPU cooler technology for both P4 and K8 CPUs -- and promises to stay at the top for some time to come.
Yet the Hyper 6 has had a few problems and has weathered a few bad reviews. One common complaint has been the fact that you must remove your motherboard from its tray to install the Hyper 6. Although this is the recommended method and the only way to install the included beefed up retention module system, Cooler Master does say that you can install the Hyper 6 into the stock retention module that comes with your motherboard. But the size, weight and stature of this premium product would suggest the trouble it may be to install the HSF, according to Cooler Master recommendations, could be well worth the effort.
But the reason for this report is not to discuss the merits of whether or not the custom retention module system is worthy of your efforts. If you need something more than the too small and too difficult to read installation instructions as an inducement to utilized the parts you paid for, you can see a better set of instructions, with full size images, at the Cooler Master Forums. This report is more concerned with a couple of other issues addressed in several reviews.
Cooler Master has made claims of silence for this CPU cooler and for good reason. If you don't over-clock and you have adequate air circulation throughout your case, it's possible to run the Hyper 6 fanless. This would, indeed, be a silent solution for many. However, most users of this product will undoubtedly want to avail themselves of the additional cooling power of the included fan. Some users will even want to add yet another fan, which Cooler Master has made accommodations for. But there seems to be a couple of problems associated with using fans on this product.
The picture below shows the 6 heatpipes that protrude though the top of the aluminum shroud.
A closer view reveals a very slight gap between the heatpipes and the edges of the holes in the shroud.
It has been reported in more than one review of this product that the pipes make a noise when the fan is in use. If you pick the unit up in your hands and shake it gently, it's not hard to see -- and hear -- that there is a definite potential for vibration noise. It rattles.
The rattle is easily remedied though. Purchase three " rubber grommets and cut them in half. You will need to shave off the excess shank.
Place the rubber grommet halves over the heatpipes and press them to the base.
Test the unit by gently shaking it and you will see that the rattling sound has now disappeared. Remove the grommet halves and add a very small amount of super glue (I used a brand called Crazy Glue) and re-position them back on the heatpipes. I used tweezers to prevent getting glue on my fingers and making it difficult to position the grommets. Hold them in place for 15 - 30 seconds to ensure a good bond.
Another problem discussed is that the included fan can only be installed in the push air, rather than draw air configuration. That is because the fan has recessed holes on one side and the included screws can only reach through the fan when the screw head is in the recessed hole.
This will make it especially difficult if you wish to use a different fan, which I recommend as a solution to yet another problem reported -- the included fan is too noisy. Although the fan included with the Hyper 6 is a high quality, high velocity fan, it is a bit on the noisy side. Cooler Master actually has quieter fans available, albeit without the attached rheostat. But that is a minor problem and one you may solve with another fan control unit (and Cooler Master has several of them too).
Just using another fan is not enough to make this HSF as quiet as it could be. I recommend installing neoprene or rubber washers, fore and aft of the fan when you mount it.
As mentioned, with a different fan (or an additional fan on the other side), you will need longer screws. The size of the screw threads in the Hyper 6 is M3 -- not your standard thread size. You can, however, use a M4 thread (seen on the left), which is slightly coarser, but it will fit. The length of the screws for this application is 30mm. If you get longer, you risk damaging the copper fins in the heatsink.
You can get M4 screws at many hardware stores, or you can order the correct size from a company like McMaster-Carr online. I ordered M3 X 30mm cap screws (right) and the washers from them.
Screw the fan into place and tighten until just snug. Do not over-tighten. The use of neoprene or rubber washers on both sides of the fan isolates it and virtually eliminates any vibration. I suggest you buy enough washers to use on all your case fans.
The difference is noticeable; not just that I used an LED fan, but that the fan I used is much quieter than the stock fan. Pretty helps too. ;)
So, with the combination of rubber grommets to silence the heatpipe rattle and the use of neoprene or rubber washers sandwiching a quieter fan, you will have not only the best cooling solution in heatpipe technology, but a nearly silent one too. Maybe even the quietest HSF of this magnitude.
Happy modding and many thanks to GideonX of GideonTech.com for letting me bring this information to you first.
Grump
2004 Jim McClain ("Grump")
Links:
www.CoolerMaster.com
www.McMaster.com
www.GideonTech.com
« Last Edit: January 19, 2019, 08:43:49 AM by Grump »
R'gards, Grump
Photographer @ JimMcClainPhotos.com
My latest non-mod related project.
BuSkillS
« Reply #1 on: June 20, 2004, 05:35:13 AM »
woah, that is one massibe heatsink.  you need to slap another fan on the otherside, if it will fit.  nice use of the groments, mann you sure are obsessed with it being "quiet".
i didnt think anyone else is on this late, huh.
computerfreke911
« Reply #2 on: June 20, 2004, 11:23:19 AM »
Thats a great article. Hope your project comes out well.
TheM@trix
« Reply #3 on: June 20, 2004, 11:33:55 AM »
What's its c/w rating?
Personally I think I would feel safer putting a lead block on my proc.
danwatt
« Reply #4 on: June 20, 2004, 02:56:15 PM »
if i'm going to shell out $50 for a cpu cooler, i'd expect it to work fine without having to do much to it. hopefully they will make an updated version? this really has a lot of potential.
Another quality post^^^
Siris_le_osiris
« Reply #5 on: June 21, 2004, 05:57:40 AM »
Best thing is seen done with this this HS is having it up and down with 2 fans and the second fan pumping the hot air straight into the PSU and out of the case.
My Hovercraft is full of eels.
s0up
« Reply #6 on: June 22, 2004, 09:08:10 PM »
Seems like to much moding (snicker). But i'd personally go with other heatsinks, TT has a simaler nice one.
Mystic Pawn
« Reply #7 on: June 22, 2004, 09:29:38 PM »
yes, but then its thermaltake
and thermaltake=sh*te
...you know, stuff like that.
s0up
« Reply #8 on: June 22, 2004, 09:33:04 PM »
Quote from: Mystic Pawn
That is true, latlely thermal take has been the...."bicycle" of the computer world.
Grump
« Reply #9 on: June 23, 2004, 12:13:06 AM »
Quote from: s0up
Too much modding? You're kidding, right? We are a bunch of modders here, aren't we? My t-shirt even says so.
These are about the easiest mods you can do. You need a screw driver and a sharp knife. Materials-wise, you need less than 5 bucks for 8 rubber washers, 4 longer screws, some Crazy Glue and 3 rubber grommets.
The washers on fans can be used on any fan in your case -- unless you like all that vibrating noise.
And Thermaltake... don't get me started. They're copy-cats. They haven't had an original idea since forever. I would put a Cooler Master product up against a Tt product any time.
The Hyper 6 isn't for everyone. It's not a traveling companion either -- you could damage your mobo if you don't remove it before transporting it. But it's a great HSF and can be made even better with a couple of simple mods. And as far as I'm concerned, if you can't mod it, I don't want it.
Grump
R'gards, Grump
Page created in 0.086 seconds with 61 queries.
