  • July 08, 2020, 08:10:59 PM
Author Topic: 110 degree elbow + tubing size?  (Read 1413 times)
Spydog101
« on: June 15, 2004, 10:10:19 AM »
I have been watercooling my pc for about two years now and just finished working on a new case and want to carry my system over to the new case.  When I first started I used 3/8 tubing, but was think about changing it to 1/2.  My blocks, res, and pump, I can get w/ 1/2 fittings, but my rad. only comes w/ 3/8 (black ice micro II).  Do you think it would still be a good idea to go w/ 1/2 even though the rad will be 3/8?  It is also time to replace my pump, so I figured this would be the best time see about the tubing size.  My other question is, does anyone know where I can find some 270 degree elbows in 3/8 or 1/2 preferably not in brass?  Thx for the help.  :D
Archaon
    • http://www.lazerlaw.com/rfa
« Reply #1 on: June 15, 2004, 03:19:57 PM »
Buy flexible tubing...?
KoRn Addict
  • It's not METAL enough!
« Reply #2 on: June 15, 2004, 04:17:16 PM »
just to let u know, a 270* elbow is no different than a 90* elbow
ClearCaseMan
    • http://www.casemodman.com
« Reply #3 on: June 15, 2004, 04:22:48 PM »
Quote from: KoRn Addict
hahaha.
But I dont want the 90's I want a 270 ;)
« Reply #4 on: June 15, 2004, 05:57:24 PM »
Quote from: ClearCaseMan
hahaha.
Buy a 90, turn around.  Then you are set.
I'd look in a hardware store in plumbing or there is an off chance that they'd have it in electrical (very off chance).  I know most are brass, but they do carry some in chromed steel.
ClearCaseMan
« Reply #5 on: June 15, 2004, 06:04:44 PM »
try a hydrilics shop they often have many types of fittings. we have a shop here called fluidair of columbia that carries dozens of types of fittings
Spydog101
« Reply #6 on: June 15, 2004, 09:40:37 PM »
my bad, I ment 110 degree elbow.  I dont know how I messed that one up.  :idiot:
Page created in 0.122 seconds with 75 queries.
