  • June 05, 2020, 12:12:16 AM
Author Topic: What happened to my comp...  (Read 646 times)
zoogly
« on: June 12, 2004, 09:43:04 AM »
What would happen if I plugged a 4-plug (not molex) wire from the power supply into one of the 3-pin fan plugs on the motherboard. I need to know which part is broken now. I think I fried my motherboard but I'm hoping I maybe hae just killed the powersupply.
ClearCaseMan
    • http://www.casemodman.com
« Reply #1 on: June 12, 2004, 09:49:10 AM »
well first something would pop then second u cry.
zoogly
« Reply #2 on: June 12, 2004, 09:53:24 AM »
Well, there was a little spark where they came into contact. Then I started to cry. :(
zoogly
« Reply #3 on: June 12, 2004, 12:02:35 PM »
I got it fixed. I removed the CMOS battery form the mobo for a while and unplugged all the power. Later I plugged it all back in and it booted fine!
jayjay1331
« Reply #4 on: June 12, 2004, 12:37:41 PM »
I had something similar happen when I dropped a HD on to the running mobo.  It threw some serious sparks, then shut off.  It would only turn back on after I unplugged the power cord for like 30 secs.
jpantoga
« Reply #5 on: June 13, 2004, 04:48:40 PM »
Quote from: jayjay1331
I think there was a guy that did that and he lost his mobo and his HD, consider yourself lucky.
Page created in 0.089 seconds with 46 queries.
