  • January 24, 2020, 09:57:00 PM
Author Topic: [?] semi-urgent switch question, !should be rather easy!  (Read 1314 times)
keristillax
« on: March 20, 2004, 03:27:21 PM »
Ok now my dilemma, i have my tv out from my comp going to my old commodore moniter and then my playstation going to it also. whenever i switch between the two (quite often) i had to go around and switch the plugs for the video. so i have a switch that i ripped out of my old power supply (the one that switches between 115v and 225v). i want to make it so i can switch between the two. the switch has 6 pins but my attempty didnt work so im still a newbie at electronics (i need directions but at least i can solder good). this is my attempt at the switch.
NOTE: my computer out is always on
NOTE: the boxes are plugs and the dark/light lines represent the 2 different wires of the plug (+ & - i would have to guess)
the result of my attempt is either way the switch is its always comp displayed, when i try the playstation it makes kind of a double image, theyre both on at the same time but like faded over eachother and its all wavy. any help would be greatly appreciated. i just realized that some people might read this to see wtf "semi-urgent" means. for those its just kind of like "sh*t wtf i dont have any idea how to do this".
Thank You
a kung-fu mastah
« Reply #1 on: March 20, 2004, 03:57:35 PM »
I don't know if the switch works like this, but I think that you have to wire it this way.
Greggyboy
« Reply #2 on: March 20, 2004, 04:17:08 PM »
Good job skylined, thats a typical pin out for a switch like that. Its a DPDT switch kerlstillax. Wouldnt a switch like that be noisy however for a video application? I would invest into something like this if you cannot afford it now.
« Reply #3 on: March 20, 2004, 07:45:12 PM »
It might not be bounceless, but it would certainly do for component video.
DurocShark
    • http://www.donimages.com
« Reply #4 on: March 21, 2004, 07:55:21 AM »
I'd have to agree with Greggyboy.  There are some decent and cheap component splitters (and RF modulators) that can be used.
BTW: C= are NOT craptastic!!! Some of them are the best composite monitors ever made. I wish I still had mine. :(
keristillax
« Reply #5 on: March 21, 2004, 03:00:12 PM »
alright thanks for the help, well at least my commodores good for something.
Page created in 0.062 seconds with 34 queries.
