  • October 31, 2020, 08:47:37 PM
Author Topic: Hauppauge WinTV-GO PCI TV Tuner Card $20 after $20MIR  (Read 827 times)
AzNPrideBoy
« on: March 15, 2004, 09:33:36 PM »
CompUSA has the Hauppauge WinTV-GO PCI TV Tuner Card for $20 after $20 rebate.
« Reply #1 on: March 15, 2004, 09:36:05 PM »
BUYER BEWARE, i have this card and the drivers suck, the software sucks, and the audio is mono and has static.
If you choose to get this card, make sure to use a program called Dscaler instead of the included winTV2000 software.
For 20$, its not that bad a deal, but if you can afford it spend 50 on the leadtek TV2000XP
AzNPrideBoy
« Reply #2 on: March 15, 2004, 09:37:49 PM »
Quote from: nemattoad
I second that.  I just posted this deal since it was only $20.  I would either get the Leadtek or an ATi product.  AIW still rock for TV tuners.
« Reply #3 on: March 15, 2004, 09:45:27 PM »
yeah, i got mine for a similar deal at a canadian staples. I cant say i regret it a lot, but i'd probably spend the extra for a better product if I had to get another card. If $$ is tight, its a decent buy.
(If anyone wants to know, It works in linux. I tried it both on redhat 9, knoppix, and fedora core 1 under xawTV and another program which i forget the name of. Works great.)
Page created in 0.081 seconds with 47 queries.
