  • June 04, 2020, 02:02:17 PM
Author Topic: Zalman fan replacement (too noisey)  (Read 1825 times)
KoRn Addict
  • It's not METAL enough!
« on: March 03, 2004, 11:10:21 PM »
hey, ive got a zalman HSF goin on, and for whatever reason, ive noticed the fan is a bit noisey. now i know i can put the resistor adapter in to slow down the fan, but i dont want to do that, i want to keep my performance.
is there any suggested fan to replace it with?
120mm fan is not preferred, the current is 92, and 80mm is just stupid. So essentially im asking is there a good 92mm fan out there that pumps about 28-35 cfm thats pretty silent?
« Reply #1 on: March 03, 2004, 11:59:11 PM »
some quiet 92mm fans
Code: [Select]
Papst 3412NGMV                        25-42 CFM         14-28 dBA
Papst                                 35 CFM              23 dBA
Panaflo L1A                           42 CFM              27 dBA
Panaflo M1A                           48 CFM             30 dBA
Vantec Stealth                        28 CFM             20 dBA
Zalman ZM-F2                          53 CFM             36 dBA
Zalman ZM-F2 w/ resistor              38 CFM             20 dBA
djpenguin
« Reply #2 on: March 04, 2004, 04:07:21 AM »
And there's your 92mm Zalman on the bottom there.  38CFM @ 20dB(a) is damn good, and you're not going to find anything better at 92mm.  Just put the resistor in.
They just keep dancing
KoRn Addict
« Reply #3 on: March 04, 2004, 11:34:29 PM »
actually, i found out that im currently running it @ 56cfm/36dba, so comparatively, im lookin for about 50ish cfm
« Reply #4 on: March 05, 2004, 12:36:55 AM »
So looking at my chart, you find the Panaflo M1A, which is 48 CFM @ 30 DBa
A large reduction in noise for a small reduction in airflow.
KoRn Addict
« Reply #5 on: March 05, 2004, 10:04:51 AM »
alright, i found the perfect fan
http://www.svc.com/en92vasphipe.html
gonna order that tonight along with a couple case fans and rounded cables
« Reply #6 on: March 05, 2004, 10:52:54 AM »
good choice on the fan, i used one of those as an intake for my other PC and it is very good. Its adjustable too so you can pick the noise level right for you.
