  • July 23, 2019, 10:27:00 AM
Poll
Is the lcd too big?
Yes
- 0 (0%)
No
- 4 (100%)
Total Members Voted: 4
Voting closed: April 02, 2004, 04:50:19 PM
Author Topic: Big LCD problem  (Read 2524 times)
Big LCD problem
« Reply #10 on: March 04, 2004, 05:57:32 PM »
If it's from a photocopier, it's probably proprietary.  If you had to pull it, that means there's not a lot of them floating around or for sale, which means that there will be nobody with software for it.  You could try searching forums in the off chance that somebody pulled the same display from the same photocopier, found the tech documents, and wrote their own software for it that they were kind enough to upload to the internet, but aside from that, you'd be better off getting a T6963c or a SED1330 LCD display and using PowerLCD.
goawaystalkers
  • Hello
    • J3hijinks
Big LCD problem
« Reply #11 on: March 04, 2004, 06:10:19 PM »
i ahve actually seen a ton of LCD with that connector and i had an LCD (full color TFT) that was pulled off a photocopier (not liek it was in it it was connected to a printsever and was a touchscreen for making copies it was about 10 inches) anywyas that ahs that same connection and it connected to a speciaL. the port it connected to was liek a aprralel port but it had 3 rows of pins... the card also ahd a vga output and it was PCI sadly whenevr i ripped open the LCD to take the plastci casing off i think i may ahve done something to the inverter board and it now no longer runs....
azmanon
    • http://www.occ.edu
Big LCD problem
« Reply #12 on: March 07, 2004, 12:09:21 AM »
www.earthlcd.com good lcds, lots of sizes and prices..
also, check out my lcd mod, maybe it can help you...
http://forums.gideontech.com/viewtopic.php?t=22582&highlight=lcd
and, does your lcd have any labels where that flat wire plugs in that look like this one??
az
Mindmaster
    • http://www.geocities.com/Mindmaster80/
Big LCD problem
« Reply #13 on: March 07, 2004, 08:23:58 AM »
Nope. It has a much smaller conection. But no labels or text.
azmanon
Big LCD problem
« Reply #14 on: March 07, 2004, 10:22:13 AM »
well that sucks, it would make it alot easier.... oh well, good luck man
Mindmaster
Big LCD problem
« Reply #15 on: March 08, 2004, 07:46:47 AM »
Thanks. Im gonna get a multimeter and test al the wires for signals... last chance i guess...
Big LCD problem
« Reply #16 on: March 08, 2004, 07:50:16 PM »
A multimeter isn't going to tell you anything.  Chances are, if the pins aren't marked, you can't find a document, and you don't know the controller, you're SOL.
Big LCD problem
« Reply #17 on: March 08, 2004, 08:39:16 PM »
viridius ir right
( ...me remembers rifles... ) :P
To know exactly what's happening you need an osciloscope. :\
Mindmaster
Big LCD problem
« Reply #18 on: March 19, 2004, 02:09:46 AM »
arrg. ah well. I didnt pay for it so all i lost was a photocopier ^^'
Page created in 0.066 seconds with 22 queries.
