Fher - Is there any other sites that explain how to attach it to your motherboard a bit more simply? Probably making myself sound like a complete doofus, but the last time I played with jumpers on my motherboard I almost fried it, so a little gunshy. I already checked and saw that my motherboard does have IR connection on the motherboard, and I already have the cd-rom digital audio cable, but mine is one solid black piece on the end, not where I can just plug in certain ends to particular places on the motherboard. *hope that made sense* Any help at all would be waaay appreciated. I've been turning my PC into a semi-HTPC and this would be great. *especially if I only have to spend a few bucks to do it
EDIT - I posted a bit too soon about not knowing where to connect it and all, I figured out the right pins to connect it to, but I'm still stumped as to how to use my digital audio cable from my cdrom to connect the IR reciever to the pins. All three wires are connected to the one black piece that usually inserts into the back of hte cdrom. Is there any particular way to seperate the wires or something? I'd hate to break my cable as I only have the one.
