  • June 02, 2020, 12:18:04 PM
Author Topic: wont boot up all the time  (Read 685 times)
mercman86
« on: February 21, 2004, 09:28:15 AM »
I am a first tmie overclocker and i tried to oc my cpu too much the first time. Now, whenever i try to boot up, it takes me a couple of times to get past the screen that tells you your chipset! COuld anyone help?
kaffine
« Reply #1 on: February 21, 2004, 10:38:59 AM »
Yeah, turn down your clock speed dood.  And if you upped the memory timings, set them more conservative.  And make sure that your PCI/AGP clocks are locked at 33 and 66 respectively.
Think
« Reply #2 on: February 21, 2004, 10:47:40 AM »
Either return to stock speeds and timings or just reduce them by quite a bit. Should solve your problem.
computerfreke911
« Reply #3 on: February 23, 2004, 02:29:04 AM »
put ur system specs on, go back to stock for now and dont oc everything at once especially if u dont know what ur doing
TMM
« Reply #4 on: February 23, 2004, 03:12:54 AM »
if its taking a few trys to POST, then windows is DEFINATLY going to be unstable, test in windows with PRIME95. clearing the CMOS is a good way to start over again if you get really unstable, its allows you to clean everything off and punch in the setting you KNOW are going to work :)
1800+ JIUHB @ 2.11ghz 10*211  || 512mb PC3500 || 120gig sata ||
Page created in 0.054 seconds with 33 queries.
