  • March 24, 2019, 01:51:03 AM
Author Topic: Troubleshoot my LCD?  (Read 973 times)
« on: February 16, 2004, 03:38:31 AM »
Like most of us, I soldered up a HD44780 LCD panel many moons ago.  It was a 2x40 so it didn't even fit in some cases, but now I'm ready to use it.
It works, but only somewhat.
If I reset the display, it comes up and runs fine for 10 seconds to 10 minutes.  Then it fails.  It blanks the screen sometimes, but frequently you fet a single line of gibberish overlaid on the test pattern
It works better when the software (CrystalControl) is told I have a slow LCD processor.
I'm guessing cold or loose solder joint somewhere in the hairball of data lines, but if someone would like to tell me which line is likely the source of this problem, or if CrystalControl doesn't work well with these displays, tell me before I break out the soldering iron
endscape
« Reply #1 on: February 16, 2004, 03:56:16 AM »
It sounds like it could be overheating, but that's just me, and I may be totally off base.  However, I have worked with a couple of lcd's and have had to put heatsinks on the controller to keep them going.
Endscape
TMM
« Reply #2 on: February 16, 2004, 05:30:37 AM »
heatsinks sounds like overkill :)
id say the power is getting spiked or shorted for a little bit. if the display looses power for a second and then gets it back, it will go to the "boot screen" thing, and then your program needs to be reset. check your wires and make sure where ever it getting power is stable and constant
:thumbsup:
1800+ JIUHB @ 2.11ghz 10*211  || 512mb PC3500 || 120gig sata ||
« Reply #3 on: February 16, 2004, 11:45:11 AM »
You could try putting a 1000 microfarad capacitor between the 5 volt line and ground.  Make sure you get the polarity correct.
Page created in 0.116 seconds with 19 queries.
