  • January 18, 2020, 06:59:26 PM
Author Topic: cheap peltiers?  (Read 2203 times)
cheap peltiers?
« Reply #10 on: April 05, 2002, 11:14:00 PM »
220 watts of heat.... right... on a heatsink??? good luck with that... thats what your problem is...
shwaip
cheap peltiers?
« Reply #11 on: April 06, 2002, 09:56:00 AM »
well, maybe if you had this, you would be able to do a pelt w/ air cooling
korndog
    • http://www.xtremgaming.com
cheap peltiers?
« Reply #12 on: April 07, 2002, 12:17:00 AM »
argh!  okey, i give in, i'm gonna build my own water cooling system.
i got an air pump and a beverage pump from a used coke machine :)
basicly it suppose to push water, coke, ect with Co2 or air, it'll still work as a water cooling system.
NOW can u guys help me find a cheap peltier?
pewterpez
cheap peltiers?
« Reply #13 on: April 07, 2002, 01:28:00 AM »
korndog....try for a water pump used for fountains and ponds instead of that kinda style of pump ;)
korndog
cheap peltiers?
« Reply #14 on: April 07, 2002, 09:02:00 PM »
it works though!... just pumps a little air with the water.  Can't afford anything better.  ANYWAYS, lets get back to the topic, cheap peltiers anyone?
shwaip
cheap peltiers?
« Reply #15 on: April 07, 2002, 09:03:00 PM »
hehe... did you try your old pelt w/ the new water cooling?
korndog
cheap peltiers?
« Reply #16 on: April 07, 2002, 11:51:00 PM »
no, but saw a couple of articals with people using a 72 watt peltier with water cooling and no frost
i want frost dammit!  now the ones with 153 watt, i can use to make ice cream, really!
shwaip
cheap peltiers?
« Reply #17 on: April 08, 2002, 12:35:00 AM »
if you want frost, go dual 172 watt pelts (you better have a good cooling system, and a big ass powersupply)
basic
cheap peltiers?
« Reply #18 on: April 08, 2002, 01:08:00 AM »
with 2 500 watt psu's, i think he has enough power to run 2 172w pelts...
korndog
cheap peltiers?
« Reply #19 on: April 08, 2002, 09:02:00 AM »
yea, my computer doesn't use up more then 300 watts, so i got plenty to spare.  but it would sucks if my water cooling system stopped working... *sizzle*
Page created in 0.062 seconds with 34 queries.
