  • December 07, 2019, 05:59:07 PM
Author Topic: Anyone know anything about connecting cold cathodes?  (Read 479 times)
nooyawkah
« on: March 27, 2002, 08:39:00 PM »
I have a cold cathode kit from PC Mods
http://pcmods.com/details.asp?ProdID=137
I broke the bulb so I tried to order another one. PC Mods doesn't show replacement bulbs on their website and that damned company never answers the phone and usually doesn't respond to e-mail.
I then ordered this from ZX Mods
http://www.zxmods.com/products/productccmodtubes.html
I can't seem to connect the two to make the bulb work. The inverter is still in the case and it's plugged into the power supply with a 4-pin molex. And it's also connected to a toggle switch. The replacement came with a 3 pin plug that won't fit into anything. I have a 3-pin to 4-pin fan adapter but it won't work with that. It seems like it's not meant to fit into it.
I put in the 2 URLs so you can see things much better than I can explain them. Any help appreciated but remember that my knowledge of electricity is less than none.
Sign me...
Liberal Arts Major
« Reply #1 on: March 27, 2002, 08:53:00 PM »
It should, since the connectors are pretty standard.  But since it doesn't, you could clip the connector from your broken bulb-if you kept it-and connect that to the leads of the new bulb.  If al else fails, you can to Action Electronics and pick up a cheap CCFL.
Page created in 0.105 seconds with 18 queries.
