  • May 17, 2021, 04:31:43 PM
Author Topic: just wondering why my p4 2.6c idles at 35 celsius ???  (Read 1145 times)
Matty_771
« on: December 10, 2003, 11:20:52 PM »
I was just wondering if my chip is faulty or is just a bad one, it seems to idle at 33 or 35 and seems a little high compared to other chips of its type. Just a few weeks ago it was idling at 27 which i was quite happy with   :D  but recently jumped up higher. When it becomes under full load it jumps up dramatically (in a matter of seconds) to 45 celsius. Just wondering whether there is something wrong!   By the way, i have adequate cooling with 5 case fans and the stock HSF which isn't upposed to be too bad. My chip was manufactured in Malaysia.
                                                       Thanks
« Reply #1 on: December 10, 2003, 11:29:43 PM »
35C is about right for that chip.  Provided you are using the stock HSF combo.
Matty_771
« Reply #2 on: December 10, 2003, 11:32:41 PM »
oh ok, thanks  :)
Siris_le_osiris
« Reply #3 on: December 11, 2003, 12:19:52 AM »
Yea 35 sounds about right if i actually run my 2.4C at stock (never happens :P) its runs around 26 / 33, but i have way more then stock cooling, 30 /39 at 3.4 gightz ;)
My Hovercraft is full of eels.
Matty_771
« Reply #4 on: December 11, 2003, 12:22:48 AM »
i wanted to overclock mine to about that but after my temps jumped i was unsure whether too or not. What sort of cooling are you using? Water?
fuSER
    • http://webpages.charter.net/aznfuser
« Reply #5 on: December 12, 2003, 07:03:52 PM »
man, those temps are fine...p4's run about in that range anyways
Siris_le_osiris
« Reply #6 on: December 13, 2003, 01:33:13 AM »
na i just have a 120 mill fan on there, much cheaper then WCing :roll:
Page created in 0.07 seconds with 33 queries.
