  • November 17, 2019, 08:36:53 PM
Author Topic: CPU cooler and vidcard cooler  (Read 1556 times)
beaversoc
« on: March 20, 2002, 10:59:00 AM »
After i put on my new cpu cooloer (chrome orb) and muy vidcard cooler(blue orb)  How long should i wait befor eusing the computer?  also should i use the stufff that comes with it thermal paste?  or artic alumina which i also ordered?  Thanks
brutal
    • http://www.brutal.tk
« Reply #1 on: March 20, 2002, 11:35:00 AM »
does the tube of adhesive state a setup time? if it doesnt maybe leave it 24 hours. im not really shure how long it takes.
i have a tube of adhesive that came with a zalman card cooler that im gonna review and it says to cure for 1 hour at 20c (68f)
« Reply #2 on: March 20, 2002, 12:01:00 PM »
I recommend using the Artic alumina instead of the thermal paste included with the Chrome Orb.  If you installed your cooler using the studs and with just thermal compound (not thermal adhesive), then you can use it right away.  That's exactly what I did.  installed the chrome orb with artic alumina compound, used the studs that came with it since the holes are aligned and fit well, slapped the card in, and started raising my core and memory values with NVMAX (which to my surprise, and probably expectedly, I had a higher stable setting).
beaversoc
« Reply #3 on: March 20, 2002, 01:15:00 PM »
WHat is NVmax how can i use it easy?
thanks
« Reply #4 on: March 20, 2002, 01:19:00 PM »
Here's the link to that:
http://www.nvmax.com/cgi-bin/nvmax.pl?action=download
it's a Tweak Utility program to help you mess around with your Nvidia based video cards.  You can set your video card overclocking values there too.
shwaip
« Reply #5 on: March 20, 2002, 05:53:00 PM »
make sure you don't try to use a shim w/ you chrome orb, your processor will cook
beaversoc
« Reply #6 on: March 21, 2002, 08:56:00 PM »
Thanks for help and info
Page created in 5.075 seconds with 18 queries.
