  • July 04, 2020, 12:25:28 PM
Author Topic: Ball and Sleeve Fans, what is the difference?  (Read 3277 times)
myr
« on: August 22, 2001, 08:16:00 PM »
What is the diference about a Ball and Sleeve Fan, the technical diferences, advantages and cons. ?
why a Sleeve Fan have a life expectancy smaller than a Ball Fan?
NMDante
  • Aaargh!
« Reply #1 on: August 23, 2001, 08:56:00 AM »
I thought it was the other way around....ball lower than sleeve...hmmm...
BUT...to answer your question.
Sleeve bearing fans are supposedly quieter than ball bearing fans.
That's the only real difference I can think of.
Antacus
« Reply #2 on: August 23, 2001, 12:02:00 PM »
Snip from Sunon's www site:
Bering System :
Precision, life-lubricated ball bearing system
Precision, oil-impregnated sintered sleeve bearing system
Now if you compare the cfm vs. noise levels of sleeve and ball they are very close (ball 1db lower on a 39cfm but sleeve 1db lower on a 43cfm). I have all BB fans so can;t give any personal feedback. Check out this page, it has a GOOD breakdown on ball vs sleeve:
http://www.comairrotron.com/Engineering/CoolingFan.htm
Page created in 0.144 seconds with 33 queries.
