  • June 03, 2020, 01:42:08 PM
Pages: 1 2 [3] 4 5   Go Down
Author Topic: HELP! RUNNING TWO PSU'S OFF OF THE ON BUTTON  (Read 6436 times)
outonanisland
« Reply #20 on: October 25, 2003, 08:49:49 PM »
ok, the green is earth, and the blue and brown go directly to the on button, the white and black wires go to the socket that the plug for the psu goes into and then to the button? im guessing i cut the blue and brown wires?
TIME FOR A SMOKE!!!
ClearCaseMan
    • http://www.casemodman.com
« Reply #21 on: October 25, 2003, 08:52:10 PM »
you are just goung to cut the wires that go to the aux plug
outonanisland
« Reply #22 on: October 25, 2003, 08:53:20 PM »
blue and brown. they are the only ones that go directly to the the aux plug
TIME FOR A SMOKE!!!
outonanisland
« Reply #23 on: October 25, 2003, 08:54:01 PM »
and can i just ungplug them from the switch rather then cut them from the aux plug?
TIME FOR A SMOKE!!!
ClearCaseMan
« Reply #24 on: October 25, 2003, 08:55:33 PM »
dude why dont you come into irc so this is easier for us
irc.gideontech.com
#gideontech
outonanisland
« Reply #25 on: October 25, 2003, 08:57:57 PM »
ok im downloading mirc, could take a while my isp is a bitch
TIME FOR A SMOKE!!!
ClearCaseMan
« Reply #26 on: October 25, 2003, 09:00:51 PM »
k
outonanisland
« Reply #27 on: October 25, 2003, 09:14:21 PM »
ok i have mirc now how do i get to the channel?
TIME FOR A SMOKE!!!
outonanisland
« Reply #28 on: October 25, 2003, 10:08:28 PM »
clearcaseman isnt answering, so if anyone else can help me it would be much appreciated, and if you can tell me how to get into the gideontech irc channel, i dont know how to use irc, lol
TIME FOR A SMOKE!!!
« Reply #29 on: October 26, 2003, 01:52:28 AM »
Connect to the server
irc.gideontech.com:6667
through your IRC client.  When the Gideontech ASCII graphic loads, type in
/join #gideontech
and you're in.
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.068 seconds with 33 queries.
