  • January 27, 2020, 05:39:55 AM
Author Topic: 3way on-off-on momentary switch  (Read 489 times)
Fanny J. Crosby
« on: October 12, 2003, 11:25:03 PM »
This is actually a car project and i am making a remote control. I have a momentary-on-off-on 2 way toggle switch to make a car go forward and reverse. HOW do I wire this?
I tried doing it like a 5v-off-12v baybus switch, but i am trying to use one battery. Am i dreaming? I would have to make the current travel one way while the switch is pulled one way, and go the opposing way while it is thrown the other. I was thinking if i split the battery terminals into 2, it would be easy, but im just not sure. I have tried to many trial and error ways of doing this to keep experimenting and also i have looked extensively for any type of wiring schematic for these online so even if you simply post a link, i will  /kiss you. Ok, maybe not, but i would be very thankful.
NOTE: batteries, not a power supply
« Reply #1 on: October 12, 2003, 11:36:13 PM »
making it go forward and reverse is just making the polarity reversed also, as far as DC motors are concered.  Try this:
Code: [Select]
to motor + lead <--o o o--> to motor - lead
to motor - lead <--o o o--> to motor + lead
the + and - on the top and bottom respectively is your battery.  when you switch it one way, it connects the + of the battery to the + of the motor.  Same goes with the - line.  when you switch it the other way, the + of the battery connects to the - of the motor, and the - of the battery to the + of the motor, reversing it.
Page created in 0.061 seconds with 34 queries.
