  • February 22, 2020, 07:14:41 AM
Author Topic: Piggy-backing LEDs  (Read 2399 times)
sickskater6911
Piggy-backing LEDs
« on: October 11, 2003, 06:19:11 PM »
ive seen it dont before but i really would like to know how
u know where they put 2 leds in one socket?
i thought maybe u just put the both in the holes (+ -) and soder it
but beofre i try nehting i wanna know im doing it right
Mossy
Piggy-backing LEDs
« Reply #1 on: October 11, 2003, 06:23:27 PM »
you may be thinking about color reversable leds, not two in one. when the current switches direction is switches color
sickskater6911
Piggy-backing LEDs
« Reply #2 on: October 11, 2003, 06:25:59 PM »
no ive seen it donw ill find a pic
sickskater6911
Piggy-backing LEDs
« Reply #3 on: October 11, 2003, 06:27:55 PM »
here
Piggy-backing LEDs
« Reply #4 on: October 11, 2003, 06:30:16 PM »
Just match up the anode and cathode.  And make sure that the voltage and current are equal too.
sickskater6911
Piggy-backing LEDs
« Reply #5 on: October 11, 2003, 06:43:54 PM »
so basicly just put the leads from both into the same holes and soder it at the bottom and it will work?
i mean +(from one LED) and +(from another) into the plus hole and vise versa for the -
Piggy-backing LEDs
« Reply #6 on: October 11, 2003, 09:24:26 PM »
I don't really get what you're trying to say, please be more clear.
sickskater6911
Piggy-backing LEDs
« Reply #7 on: October 11, 2003, 09:26:37 PM »
dont worry aboot it guys i found a guy to explain it to me on a diff forum
#include
Piggy-backing LEDs
« Reply #8 on: October 12, 2003, 01:38:05 AM »
Im trying to do that to my mouse too so how do you do it because I cant get it to work
Squeak
Piggy-backing LEDs
« Reply #9 on: October 12, 2003, 02:27:35 AM »
first of all he wants two leds running off the one circuit
so in order to acheive the same brightness in both leds its important that they are the same voltage and current
then its just a matter of soldering the two anodes together, and the two cathodes together then treating them as one led
just stick it in and it should work
should :P
Page created in 0.053 seconds with 34 queries.
