  • September 24, 2020, 06:21:38 PM
Author Topic: How would I hook up a CU20025SCPB-T20A VFD  (Read 1513 times)
chase!
  • The Internet!
« on: October 10, 2003, 11:41:26 AM »
http://www.qscomp.cz/Pdf/CU20025SCPB-T20A-05.pdf
I bought this VFD above, and was wondering if I could hook it up to serial? Serial is only like 1 wire, which would be ideal for where it's going to go. Can someone tell me which pin (if any) can hook up to serial?
1 more, thing, it seems to have 2 different places to power it, 1 is like a 3 pin fan header, can I just use that source for power, and not the VCC with the 16 pins?
Here is an image of it
timid1
« Reply #1 on: October 10, 2003, 10:37:34 PM »
There's only one place to power it.  The spec sheet is clear on that.  And it CAN be run on serial.  Maybe viridius can help with the pin-outs.
chase!
  • The Internet!
« Reply #2 on: October 10, 2003, 10:56:16 PM »
Pewter and i7dude helped me. We think SIN/TEST is the serial pin. SIN = Serial INput.
Also, about the power, I was also refering to the VCC 5c plugs, they're on the IC pins. Pewter also helped me with that.
strongShock
    • http://www.strongshock.com
« Reply #3 on: October 11, 2003, 01:32:58 AM »
sounds about right to me. you probably also want to hook it up to DB-3 on your serial port. do you have plans for some sort of software to drive it?
Page created in 0.088 seconds with 32 queries.
