  • August 16, 2022, 06:01:10 AM
Author Topic: Reviews: Aurora 350W Power Supply  (Read 3797 times)
« on: October 09, 2003, 10:39:16 PM »
some pre-modded fun:
« Reply #1 on: October 09, 2003, 10:47:14 PM »
First review I've seen that tested the short circuit protection feature of a PSU.
« Reply #2 on: October 09, 2003, 10:55:46 PM »
well, it's more because brutal sucks at the hardware, so he shorts things out consistently ;)
Neema12
« Reply #3 on: October 09, 2003, 11:07:47 PM »
these psu's are very nice for noise. Silentpcreview.com will elebrate on this, but these use 120mm at low rpm to replace 2 80mm with make more that 3x the noise. The air turbulace(noise) is also reduced with vent holes everywhere on back side, and arent made like the $10 single fan psu. my 2 cents?
RaDragon
  • Tee hee hee.
    • RaDragon.com
« Reply #4 on: October 10, 2003, 01:49:18 AM »
I like the little "honeycomb" holes on that PSU -- my PSU gets hot that I wish it had more vents like that.
On a side note: that's a pretty big product box for a PSU!  :o
Geet Lord
« Reply #5 on: October 10, 2003, 12:17:33 PM »
yeah I really like the design of  this PSU, it has a quieter fan and those wonderfull holes on the front and backwhic would both help with the temperature and the noise levels...dosnt leave much to mod except paint and a window...
brutal
    • http://www.brutal.tk
« Reply #6 on: October 11, 2003, 07:12:14 PM »
Its not that I am bad with hardware, I have to make sure hardware is useable for people like Data :)
« Reply #7 on: October 12, 2003, 02:08:43 PM »
You should have dropped a running dremel into the inside then.
Blooz1
« Reply #8 on: October 12, 2003, 03:06:27 PM »
I picked up the "plain-jane" version of this PS (no LED fan, regular finish) for $36 at NewEgg. I bought it for a spare, but now I wanna use it!
It's really quiet, and after I paint and sleeve it, I think I'm gonna pop it in my Lian-Li system!
Neema12
« Reply #9 on: October 13, 2003, 12:04:52 PM »
im to lazy to check, but is the $36 psu only 300w?
Page created in 0.326 seconds with 33 queries.
