  • March 31, 2020, 02:25:58 PM
Author Topic: Breedboard Help...  (Read 1807 times)
ModFX
Breedboard Help...
« on: October 05, 2003, 06:33:59 PM »
I bought a breedboard today at radio shck , http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F002%5F000&product%5Fid=276%2D175 , anyway I need a little info on it and they don't tell me sh*t even in there documents. Anyway i wondering if you could help me out by either telling me how the current going through works or by sending em to some site.
BiGReD
Breedboard Help...
« Reply #1 on: October 05, 2003, 06:49:12 PM »
It's connected like this:
Code: [Select]
So you usually use one side for + and the other side for -, put IC's straddling the middle with no contacts, then use all the middle contacts to wire the ic's.[/url]
Breedboard Help...
« Reply #2 on: October 05, 2003, 06:55:26 PM »
Yeah, the vertical strips (in Bigred's diagram) are the power buses.  I remember my first breadboard.  I pulled the foam off of the back to find out how they were hooked up.
Breedboard Help...
« Reply #3 on: October 05, 2003, 06:56:25 PM »
i have the same one.  you can look at the bottom of the board and see the traces on the paper backing, which is basically what bigred just illustrated.
DurocShark
    • http://www.donimages.com
Breedboard Help...
« Reply #4 on: October 06, 2003, 07:47:29 AM »
Wow... Breedboard... I've only been able to find Breadboard... ;)
It's been so long since I've used one... I usually solder things together to test nowadays. I'm too lazy to breadboard the circuit. heh
Breedboard Help...
« Reply #5 on: October 06, 2003, 01:06:17 PM »
What??????!!!!!!!!!
To test things you don't solder!
You just put your ICs, resistors, capacitors, leds, etc, etc in those lil sockets, and you may have soldered something the wrong way and the circuit won't work or won't work as you expected.
DurocShark
Breedboard Help...
« Reply #6 on: October 06, 2003, 01:18:19 PM »
Quote from: Skylined
What??????!!!!!!!!!
I *said* I was lazy...  :lol:
Breedboard Help...
« Reply #7 on: October 06, 2003, 01:45:51 PM »
:wtf:
PetaHertz
Breedboard Help...
« Reply #8 on: October 07, 2003, 03:57:15 PM »
Essentially, just remember that the long rows of holes on the sides of the board (power buses) are connected, and each row of 5 holes in the middle part are connected.
Page created in 0.07 seconds with 47 queries.
