  • February 22, 2020, 12:25:52 PM
Pages: [1] 2 3   Go Down
Author Topic: how to make a homecomming mum  (Read 5850 times)
rallger
« on: September 28, 2003, 10:15:01 PM »
this may be a little off sbject but im gonna try to make a mum for my homecomming date. and i want to have like 4 or 5 green led's in it
so is there ny tutorials on how many bateries and resistors and stuff
any help would be great thanks
« Reply #1 on: September 28, 2003, 11:13:01 PM »
Do you have specs on those LEDs?  If you do, you can go here.
Melancholinpolly
« Reply #2 on: September 28, 2003, 11:14:46 PM »
.......your making a what?
PetaHertz
« Reply #3 on: September 28, 2003, 11:18:45 PM »
A chrysanthemum.  It's a flower girls wear as a corsage (sp?), and he wants to make it out of LEDs
Melancholinpolly
« Reply #4 on: September 28, 2003, 11:19:44 PM »
ohhh.......um
*cough*dork*cough*
it's a nifty idea though.
Infindense
« Reply #5 on: September 28, 2003, 11:46:02 PM »
Unless she's a geek like you I think you'll get slapped and most everyone else will laugh at you.  I don't think you'll be getting lucky on homecomming night my friend.
Bartman007
« Reply #6 on: September 29, 2003, 12:59:05 AM »
If you really wanted to you could have a stealth Geek Corsage.  All the electronics are hidden... um wait a sec, you would probably get slapped anyway because to turn it on it would look like you are trying coping a feel.  Oops, good idea anyway
Melancholinpolly
« Reply #7 on: September 29, 2003, 01:16:30 AM »
it's a good idea on the drawing board.......but no go in real life :/
TemplaraPheonix
« Reply #8 on: September 29, 2003, 01:17:01 AM »
You'd be surprised how many non-geek girls are impressed by something shinny or glowing green. I have a translucent mouse that glows green, it always impresses the girls in my dorm.
Anyway, it's really easy to do. Just assume a resistance of 135 Ohms for the LED and try to get the current under 20 mAs. For example with 5 LEDs and a 9V battery you'd have 13 mA and thus be fine running in series directly off the battery. This configuration has the easiest wiring, but isn't that bright. You can maximize the current with parallel wiring and changing the input voltage. 5 LEDs in a parallel array with a 5 Ohm resistor on 4.5V input would give 28 mA making your array brighter. Technically you could optomize it for exactly 30 mA, but things get more complex. For example, you can pull 9V or 4.5V with standard batteries. 4.5V being 3 AA batteries.
As for using the device, I'd put it in on remote control. That would be cool...
Neema12
« Reply #9 on: September 29, 2003, 01:20:40 AM »
I really think that will look cool, but make you look like a loser, lol major geek. I dont think a female will be impressed unless she is a loser too. My 2 cents?
Pages: [1] 2 3   Go Up
Page created in 0.075 seconds with 33 queries.
