  • September 28, 2020, 06:47:32 PM
Author Topic: video adapter  (Read 2774 times)
weirdo1491
video adapter
« on: September 26, 2003, 09:16:58 PM »
my question is is it possible to connect a crt monitor to a svideo connector in a simple way? i don't want to spend a lot of money on componets and build something when i can go out and buy a color lcd monitor and probibly use that. any help would be appreciated.
BiGReD
video adapter
« Reply #1 on: September 26, 2003, 09:28:47 PM »
Do you mean you want to hook a DVD player or something into a monitor?  It wont be easy, i havent even seen boxes that do that.  If you have a computer for it though, just go get a tv tuner card, you'll get both TV and SVIDEO and COMPOSITE IN.
weirdo1491
video adapter
« Reply #2 on: September 26, 2003, 09:35:23 PM »
no, what i want to do is add a second monitor to my comp but my video card will only let mr attach an svideo along w/ the normal vga. i hope that helps some.
BiGReD
video adapter
« Reply #3 on: September 26, 2003, 09:53:03 PM »
Same thing then, you can't really attach another monitor through the svid port.  You could attach a TV.  Even if you could attach a monitor, you resolution would be limited to 800x600 max or lower depending on your video card.
You can probably get a cheap mx440 with dual outputs for under $50 US now, I don't know what you have now but its probably an upgrade for you, as far as i know i haven't seen anything above a mx440 without dual outputs.
video adapter
« Reply #4 on: September 26, 2003, 09:59:08 PM »
s-video output is pretty crappy for use as a second display, unless you are using it for games, movies, and stuff like that, text and smaller things really are terrible on it.
snow veil
video adapter
« Reply #5 on: September 26, 2003, 10:16:37 PM »
http://www.baber.com/baber/products/cheese_box.htm
That's one of the many boxes that will do it, however they're not cheap.  Last time I checked I think they were starting around 70 bucks or so.
Look around newegg and you'll find a few more probably, but this is a notorious unit simply for it's name and shape.
weirdo1491
video adapter
« Reply #6 on: September 27, 2003, 11:10:48 AM »
i was lookin on **** and they had this vga to composite & svideo adapter. would i be able to use that in reverse to get what i want? i know i'll have to get a cable of some sort because the vga connector goes into the computer and i want it the other way around if you understand what i just said.
weirdo1491
video adapter
« Reply #7 on: September 27, 2003, 11:11:38 AM »
What did we say about trying to work around the censor?
-GTF Mod
weirdo1491
video adapter
« Reply #8 on: October 11, 2003, 09:17:26 PM »
will somebody please answer my last question.
video adapter
« Reply #9 on: October 11, 2003, 09:24:43 PM »
I don't think you can plug it in reverse since the VGA-Svideo adapters are plugged in the VGA ports on the computer.  And I believe those adapters only work with the laptops that came with them.  I bought one from someone in the forums (sorry if i forgot your name :D you know who you are) and it doesn't work on normal PC videocards.
Page created in 1.595 seconds with 34 queries.
