  • February 22, 2020, 07:07:13 AM
Author Topic: problems with rechargable batteries?? Help  (Read 3255 times)
Neema12
« on: September 26, 2003, 08:54:50 PM »
http://shop4.outpost.com/product/3765546
I cant get these batteries to charge? I plug them in, the led turns on, in a few hours they turn off, as if there ready. I plug them in cd players, camers, mice, ect. They dont work?
daPyr0x
« Reply #1 on: September 26, 2003, 10:26:01 PM »
they're probly ni-cd's so that'll happen.
TemplaraPheonix
« Reply #2 on: September 26, 2003, 10:43:35 PM »
Your device probably needs a higher voltage. Many recharagables don't give the full output. For example most 9V rechargables are only 7.2V. I suggest getting some higher quality batteries.
« Reply #3 on: September 27, 2003, 12:23:47 AM »
Like templaraPheonix said.. Most Ni-CD battery's are lower powered. AA & AAA are 1.2V and not 1.5V like store bought.
Standard Charge time on battery's is 4-8 hours. depending on the 1st charge will tell how long the battery will last. So if you didnt charge them all of the way they never will charge up to Full.
snow veil
« Reply #4 on: September 27, 2003, 06:56:15 AM »
What type of rechargable batteries are they?  The 1.2V is kind of irrelevant, because most devices still work when standard alkaline batteries drop to that level anyway.
Some chargers have a NiCD/Ni-Mh switch on them, I know mine does.  If it does, make sure that it's set to correspond with the batteries that it needs to charge.
Neema12
« Reply #5 on: September 27, 2003, 11:01:23 AM »
yes, this has a switch on the side, a NiCD/Ni-Mh switch l think. What do you suggest I do to get it working?
snow veil
« Reply #6 on: September 28, 2003, 12:23:42 AM »
I suggest you look at what type of batteries you're charging, and set it to that.
 :wtf:
Neema12
« Reply #7 on: September 28, 2003, 07:46:39 PM »
I tryed both, and still no charge.
Neema12
« Reply #8 on: October 02, 2003, 09:17:23 PM »
No solution, any more ideas. Do you guys need pics
Neema12
« Reply #9 on: October 09, 2003, 12:02:56 AM »
same problem... anyone...
Page created in 0.07 seconds with 33 queries.
