  • April 04, 2020, 11:45:27 PM
Author Topic: -8, -7 volt line from PSU  (Read 3275 times)
endscape
« on: September 25, 2003, 10:09:16 PM »
Hello all-
I just bought a big n' wonderful 240 x 128 LCD that I'm hooking up to run Liquid MP3.  The schematics I've found to wire it to a parallel port are a tad bit conflicting.  One that I've found says to ground a certain pin, while the other wiring diagram says I need a -8 or -7 volt line.
Anyone know how to create the -8/-7 volt line from a normal computer PSU?
Any help would be greatly appretciated,
Endscape
« Reply #1 on: September 25, 2003, 10:17:32 PM »
While there is no -7 volt line from the PSU, you could always get a -7 volt regulator and hook it on to the -12 volt line.
daPyr0x
« Reply #2 on: September 25, 2003, 10:44:32 PM »
vir; couldn't you just use 12v as VCC and use 5v as gnd?
or wait, -7?
yeah
+5v as gnd, -12v as vcc.
PIYIRIO
« Reply #3 on: September 25, 2003, 10:54:17 PM »
um... you'd have to use the -12 as the postivive and -5 as a ground for -7 volts, -12 and +5 would give you 17 and fry your -7volt stuff. they're all on the atx mobo connector. i don't know what wire is what now though so you gotta google.
« Reply #4 on: September 25, 2003, 10:58:25 PM »
Messing with mobo connectors isn't a good idea.
endscape
« Reply #5 on: September 25, 2003, 11:03:26 PM »
well actually in this case I could, since I'm going to have a second ATX PSU running the LCD (and some fans and what not)
Endscape
« Reply #6 on: September 25, 2003, 11:36:38 PM »
Since the rest of the circuit will have voltages relative to true ground (zero volts), the -7 portion of the circuit must be at an actual -7 volts.
endscape
« Reply #7 on: September 26, 2003, 12:59:03 AM »
Quote from: viridius
I may just be illiterate, but I dont completly understand that.  Could someone explain it a little more, or point me in the right direction?
Thanks,
Endscape
« Reply #8 on: September 26, 2003, 01:52:47 AM »
Ground is always a reference.
So the -7V has to be a real value.
endscape
« Reply #9 on: September 26, 2003, 02:09:11 AM »
AHHHH, I thought that's what he meant, but wasn't sure, thanks.
Any more thoughts on getting -7 volts from an ATX PSU?
Page created in 0.077 seconds with 48 queries.
