  • April 01, 2020, 01:03:31 PM
Author Topic: 5v+7v  (Read 2068 times)
castor jay
5v+7v
« on: September 24, 2003, 03:30:14 PM »
if i solder the 5v and the 7v wires together, the end result will be 12v right. yes i know 5+ 7+ is 12 thats not the question, i just want to know if it will do that or will it just supply the highest one, that being 7
---7v----\
----G----| ____12V
----G----|
---5v----/
5v+7v
« Reply #1 on: September 24, 2003, 04:19:36 PM »
Are you talking about a PSU?
    • The Site Of Doom
5v+7v
« Reply #2 on: September 24, 2003, 04:21:31 PM »
If i remember my previous exparaments right (i can't find my modding notebooK) you will only get 7 volts
5v+7v
« Reply #3 on: September 24, 2003, 04:44:19 PM »
Since there is no 7 volt wire on the PSU (7 volts being the difference between 5 and 12 volts), you could be thinking of:
A: Soldering both the 5 and 12 volt wires to another wire, which means you will short out your PSU
or
B: Using the 12 volt wire that you have associated with the 5 volt common for a potential difference of 7 volts.  You will also short out your PSU like this.  Why don't you just use the 12 volt rail?
Tramodeus
    • http://www.extrememhz.com
5v+7v
« Reply #4 on: September 24, 2003, 05:46:11 PM »
yeah...don't cross power wires...unless you like sparks.
Tom
AMD_Junk13
    • Ross Computer Technologies
5v+7v
« Reply #5 on: September 24, 2003, 09:09:56 PM »
There is no 7volt on a PSU.
Note that if you use the 12volt as the (+) and the 5volt as the (-) you get 7volts. This is used mostly for quieting a case fan. Plz forgive bad ASCI  :P
Molex--------------------------Fan
______
12v---.|Yellow ------------->To pos(+)
G------|Black
G------|Black
5v___.|Red----------------->To Neg(-)
New specs tba...
orion
5v+7v
« Reply #6 on: September 24, 2003, 11:18:48 PM »
Quote from: AMD_Junk13
I think you mean this:
Code: [Select]
12v---|Yellow ------------->To pos(+)
G-----|Black
G-----|Black
5v----|Red----------------->To Neg(-)
Re: 5v+7v
« Reply #7 on: September 24, 2003, 11:27:52 PM »
Quote from: castor jay
---7v----\
----G----| ____12V
----G----|
---5v----/
Actually the standard molex looks like this:
---12v--\
----G----|
----G----|
---05v--/
strongShock
    • http://www.strongshock.com
5v+7v
« Reply #8 on: September 24, 2003, 11:52:31 PM »
viridius is right. if you solder a 5VDC & 7VDC wire together, you won't get 12VDc. you won't even get 7VDC or 5VDc. you will get 0V and some smoke.
if you mean powering off of 7VDC with a 5V reference, like AMD_Junk13 is talking about, you'd get 2VDC.
in reality, you probably mean 12VDC power referenced from 5VDC. in this case, you'll get 7VDC.
good luck bro!
Page created in 0.075 seconds with 62 queries.
