  • September 28, 2020, 10:44:51 PM
Author Topic: Swappable HD  (Read 404 times)
kramrazek
Swappable HD
« on: September 22, 2003, 07:33:39 AM »
Anybody have any experience with swappable HDs? I saw this casing on Vantec's website and thought it looked pretty sweet. Any thoughts on this or something else to sink into a spare bay?
khain13
Swappable HD
« Reply #1 on: September 22, 2003, 07:45:31 AM »
I've never used one as a secondary drive, but we use them for the primary drive in our labs at my school. you just get a blank drive at the beginning of the class and install the OS and we play with security and network utilities. then at the end of the semester we format and they're ready for the next semester's class.
We pretty much do everything half-assed around here.
ClearCaseMan
    • http://www.casemodman.com
Swappable HD
« Reply #2 on: September 22, 2003, 07:50:21 AM »
well they are nice to have but you need to determine is wether yo uwant a hot swapable(van be changed live) or passive (power down and change using a drive sled)
Swappable HD
« Reply #3 on: September 22, 2003, 08:25:43 AM »
I would check to see if it is just a drive cage or if you had the hardware that it will alow it to be hot swapable (Note most EIDE controllers are not hot Swapable).
Page created in 0.062 seconds with 33 queries.
