  • November 24, 2020, 04:24:16 PM
Author Topic: Mouse LED replacement MOD  (Read 2646 times)
« Reply #10 on: September 22, 2003, 11:13:06 AM »
Having put a UV LED in a mouse. It is limited to being used only on a UV surface (White). Yes the mouse looks sweet with the UV Glow. But Mousing is an issue.
« Reply #11 on: September 22, 2003, 06:48:22 PM »
That's why I say use an IR and a UV LED together.  UV glow, superior invisible IR tracking.
BiGReD
« Reply #12 on: September 26, 2003, 09:50:28 PM »
Hey, I just changed my mouse LED to blue (from red) and the tracking seems to be the same.  It looks a ton nicer now though.  I'll take a pic in a few mins.  It's an awesome mouse.
TemplaraPheonix
« Reply #13 on: September 26, 2003, 10:53:38 PM »
I chanaged mine to green. Works fine, I disabled the on/ off part by using the 5V line directly and increased the brightness by using an array of three 7,000 mC LEDs. I found my mouse is much more responsive as well as much cooler. I want to try an IR and put it on a switch, since I don't always want a glowing green mouse (such as when I try to go to sleep). Anybody try an IR yet.
Page created in 0.112 seconds with 34 queries.
