  • January 23, 2021, 12:41:31 PM
Author Topic: Mouse LED replacement MOD  (Read 2714 times)
Daully
« on: September 21, 2003, 08:49:16 PM »
Well ive done it b/f just have a question about some LED's. . . . . .
1) Does anyone know were i can get some UV LED's bright enough
2)Could i use two colors, such as blue and UV. . . . .
« Reply #1 on: September 21, 2003, 08:56:54 PM »
You may have some problems with UV LEDs because the sensor is designed to work best with infrared, which is at the other end of the visible spectrum.  Of course, if you put an IR LED in there, you can use whatever other colors you want to.
Daully
« Reply #2 on: September 21, 2003, 09:09:29 PM »
Hmmm would a white LED work? i have the limited edition (or so its called) microsoft wireless keyboard n mouse, cool white looken, and the white led would just add to the coolness lol :)
« Reply #3 on: September 21, 2003, 09:14:27 PM »
I dont mean to hi-jack your thread here, but I think it would be awesome, to have one of those high-output IR LEDs in a mouse that radio shack sells, would that work, without putting in any other LEDs, just that one?
Mortal_Wombat
« Reply #4 on: September 21, 2003, 09:16:33 PM »
yeah it should work....of course i like my red mouse led...i blind people with it when im at a lan hehehheh
« Reply #5 on: September 21, 2003, 09:25:21 PM »
You could try a white LED.  I'd probably work, but you might lose some tracking, especially on dark surfaces.
daPyr0x
« Reply #6 on: September 21, 2003, 10:12:45 PM »
I wonder if it'd work with IR...that'd be really cool
cuz it'd look like ur mouse was off :-p
« Reply #7 on: September 21, 2003, 10:17:07 PM »
The LED illuminates the area so that the camera can see the change in surface pattern clearly.  As long as the LED can make the surface bright enough, your LED is fine.  As for using UV LEDs, if it doesn't work, try using a mouse pad with UV reactive patterns on it.  maybe when the UV LED lights on the surface, the patterns will glow and the camera will detect the change and register the movement.  For IR LEDs, not sure if it would work, but make sure you use an IR emitter, not a receiver.
fuzzball172
« Reply #8 on: September 22, 2003, 02:19:23 AM »
www.lsdiodes.com sells UV leds
DurocShark
    • http://www.donimages.com
« Reply #9 on: September 22, 2003, 10:38:37 AM »
Quote from: fuzzball172
I've got some, and they're great. Thinking about doing this mod on my son's mouse... :D
Page created in 0.081 seconds with 47 queries.
