  • July 13, 2020, 02:10:18 AM
Author Topic: Baybus  (Read 2086 times)
m3x1c4nm0nk3y
Baybus
« on: September 16, 2003, 12:40:18 PM »
I wanna make a baybus that uses a spdt switches so that I can try to fit 10 switches and 20 leds one drive bay. I was wondering if anyone has any ideas on how to do this.
Baybus
« Reply #1 on: September 16, 2003, 12:46:22 PM »
if it's just gonna be on/off, or maybe 12v/off/7v, or 12v/off/5v kind of switching, then you could use small slide switches and position them vertically, hoping you could fit like 10 on a 5.25" bay plate.  As for the wiring, you can refer to fanbus.com.
Stinkygeek
Baybus
« Reply #2 on: September 16, 2003, 12:59:58 PM »
Not sure about the switches, X2's idea sounds good. As for the led's maybe you could use bi or tri-colored ones to eleminate the need for so many. That might save you a little room.
Baybus
« Reply #3 on: September 16, 2003, 02:56:59 PM »
Why so many switches?
Bi colour leds are the best choice if you're gonna switch from 5v/12v or 7v/12v since you'll need less room for the leds, less soldering, less resistors, and you won't have a big wire mess.
m3x1c4nm0nk3y
Baybus
« Reply #4 on: September 17, 2003, 12:04:36 AM »
The reason there are so many switches is cause i have 9 fans, plus 4 ccfl's and neon wire. But I want it to be a 7v/off/12v cause my 80s need at least 6v.
Apraxhren
Baybus
« Reply #5 on: September 17, 2003, 12:11:55 AM »
you could try some submini spdt switches you might be able to fit 10 with the leds above and below
Baybus
« Reply #6 on: September 17, 2003, 12:27:31 AM »
m3x1c4nm0nk3y: then you need DPDT switches.
If I were you I would use bicolour leds.
Here you have a schematic
Page created in 0.076 seconds with 34 queries.
