  • April 01, 2020, 11:39:13 AM
Author Topic: dpdt switches  (Read 1646 times)
hermangarza
dpdt switches
« on: September 15, 2003, 05:22:29 PM »
are power winows switches and door lock switches dpdt. ford uses switching polarity and instead of having to cross wires to lower window would a dpdt switch work?  two wires from the window motor and a power and ground from the dash a total of 4 wires but the switch has 6 terminals?
thanks
dpdt switches
« Reply #1 on: September 15, 2003, 05:35:42 PM »
I would guess they used a DPDT switch.  A DPDT switch has legs set up like this:
Code: [Select]
o o o
o o o
first position
o-o o
o-o o
second position
o o-o
o o-o
so you could probably wire it like this, reversing the polarity at each position:
to motor + lead <--o o o--> to motor - lead
to motor - lead <--o o o--> to motor + lead
hermangarza
dpdt switches
« Reply #2 on: September 15, 2003, 06:09:17 PM »
Code: [Select]
to motor + lead<--o o o
would this work with the middle terminals empty?
dpdt switches
« Reply #3 on: September 15, 2003, 08:18:48 PM »
nope.  the middle terminals connect to either the left or right terminals.  The outer terminals will never be connected to each other from within the switch.
hermangarza
dpdt switches
« Reply #4 on: September 15, 2003, 10:00:43 PM »
there are 6 terminals and 4 wires i always tought that the two wires from the motor would be on two terminals on the left of the switch and the positive and ground on the right two terminals. ill try to draw a diagram tommarow
hermangarza
dpdt switches
« Reply #5 on: September 16, 2003, 07:27:48 PM »
thats the way i was thinking but im still a bit confused
Page created in 0.075 seconds with 32 queries.
