  • June 07, 2020, 12:13:29 AM
Author Topic: Led question  (Read 1188 times)
gilgamesh
Led question
« on: September 13, 2003, 09:07:07 AM »
I haven't done much iring at all... This may seem like a stupid question but,
how many volts are the power and hdd led connectors?
probably need a resistor anyways...
Fump
Led question
« Reply #1 on: September 13, 2003, 09:30:47 AM »
the voltage is enough to run a led straight off it, so about 2.5V or somthing like that. if you are goin 2 replace the leds on the power and HDD then you can jus swap them for what u want (5V or 12V leds wont work as well as the lower voltage 1's.) hope that helps.
Page created in 0.109 seconds with 34 queries.
