  • July 03, 2020, 01:51:20 PM
Author Topic: Rotary Switches  (Read 3221 times)
Rotary Switches
« Reply #10 on: September 09, 2003, 11:32:36 PM »
If that is what you want, then wait some weeks, right now I'm making something a lil bit better than that.
I might make a guide about it, if not I'll make a post.
It's gonna take me some time because I won't only be a 6 fan controller. :)
weirdo1491
Rotary Switches
« Reply #11 on: September 09, 2003, 11:34:52 PM »
i have no knowledge of a rotary encoder and how it works, but i also haven't try to search yet but i won't be able to do that today because i have other, more important thngs to do right now. i'm willing to go look them up tomorrow but it will be later in the afternoon cause of work. if you feel like putting a link or something that would help me out a lot but if not that ok to. but thanks for the idea.
weirdo1491
Rotary Switches
« Reply #12 on: September 09, 2003, 11:39:21 PM »
i also forgot to mention one tiny but more than likely important thing. i was going to try to set up the switch so when i turn to a certain fan it would show the temp of the area the fan is blowing on. the temp would be displayed on a pre built thermometer (doubt that would make a difference) but that is the general idea. if that changes things let me know cause i want to get this thing up and running ASAP. thanks for your help
flamingboard
    • My Portfolio
Rotary Switches
« Reply #13 on: September 10, 2003, 12:39:56 AM »
someone should make this....
it would be a fully digital baybus. backlit LCD that would show hardware info and let you rotate through all the fans in your system and change their speeds with just a push of a button. probably really hard but if someone makes it i want royalties!!! :-D
http://elwood.pionet.net/~soucada/screen.jpg
Page created in 0.095 seconds with 34 queries.
