  • January 27, 2020, 05:20:52 AM
Author Topic: How to power an LED  (Read 4338 times)
-snake-
How to power an LED
« Reply #10 on: September 09, 2003, 05:47:14 PM »
I read a guide on this site about doing it and the guy uses a 100ohm resistor but another site had it directly plugged with no resistor wouldnt this blow it up?
How to power an LED
« Reply #11 on: September 09, 2003, 05:48:41 PM »
he used a LED rated 5v and he wired it directly to the 5v line.
-snake-
How to power an LED
« Reply #12 on: September 09, 2003, 05:52:31 PM »
I checked up on antecs site for my SX1040BII  and they dont specify what voltage of LEDs are in the front, is there a standard voltage for all leds infront of all cases?
How to power an LED
« Reply #13 on: September 09, 2003, 06:16:32 PM »
I don't think mobo manufacturers would even have the voltage outputted from the indicator headers (the LEDs in the front) on the specs.  But according to some people who tried to measure it, it's usually between 2-3v, and typical diffused LEDs (not those clear superbright ones but those stock LEDs included in cases) are rated around 2-3v also, if not lower.
broctannn
How to power an LED
« Reply #14 on: September 09, 2003, 06:28:10 PM »
no, the voltage is probably anywhere from 3.5 to 5v but why would you want to power a couple or orange or yellow leds to be allway on on the front of your case, hit lsdiodes.com and get some bloo or something that matches your color sceme
How to power an LED
« Reply #15 on: September 09, 2003, 08:01:38 PM »
Brutal has a good LED calculator on his webpage.    It's a simple application of Ohm's law (E=IR where E is EMF in volts, I is current in amps, and R is resistance in ohms).  Rearranged to solve for resistance, you get R=E/I where R is the resistance of the resistor you need to put in series with the LED, E is the difference between the LED's operating voltage (Vf), and I is the nominal current in amps that the LED runs at (Iop).
Page created in 0.05 seconds with 33 queries.
