  • March 31, 2020, 02:32:47 PM
Author Topic: LED chase  (Read 1424 times)
Wingrad
    • http://www.cfztech.com
LED chase
« on: September 08, 2003, 04:24:16 PM »
I am planning a mod on my front bezel for my thermaltake xaser 2 case. it has an antec case style "radiator" on the front and I am looking to put a bunch of blue led's in it. the Led's are 3.6 volt and I am thinking of making them run a chase pattern around the bezel. could this be done using a 555 timer IC? or would I have to use a series of capacitors in series to get what I want? any input would be appretiated
renderblender
LED chase
« Reply #1 on: September 08, 2003, 04:43:58 PM »
If you need any 555 timers, I have a lot of them, PM me.
LED chase
« Reply #2 on: September 08, 2003, 05:37:55 PM »
You just need one timer, some AND gates, and as many 4017 decade counters as you want.  Check it out here.  If you want to cascade counters, you can get 9 outputs from the first counter and eight from each successive counter.
renderblender
LED chase
« Reply #3 on: September 08, 2003, 05:59:16 PM »
You can get free samples of these at ti.com
