  • January 27, 2020, 05:19:18 AM
Author Topic: What resistor will i need?  (Read 1338 times)
nick_69
« on: September 07, 2003, 09:44:03 PM »
I am going to connect 4 LEDS up to the 6v on the PSU. The LED's are Ultra bright blue with an MCD of 1500 and I think they run on 3.5 volts. What resistor will i need to run them?
Also while Im here I wll also announce that I have almost finished my Playstation Mod. I have changed a few things though, I have put hinges on the lid, I have put an on/off switch and a reset switch on the playstation and i have put the Power supply in a case so I dont keep electricuting myself when I open the case.
I am also planning on making an inferred remote to turn it on and off and I am also planning in putting leds under the Playstation lid so it lights up. When I have finished this I will post some pics.
« Reply #1 on: September 07, 2003, 09:50:33 PM »
wrong forum, moved to Electronics.
DurocShark
    • http://www.donimages.com
« Reply #2 on: September 07, 2003, 09:53:17 PM »
If you run each individually with a resistor, a 1/4 watt 220 ohm resistor would be fine.
If you want to do a series, 2 of them un-resistored would work (read the other comments about uncontrolled series use, however).
I run 4 3.3v led's in series on the 12v line of my machine with no problems. In fact, there's no detectable brightness between using them that way or using individuals with a 680 ohm resistor.
« Reply #3 on: September 07, 2003, 10:17:51 PM »
6V from the PSU? Or do you mean 7V?
Can you tell me the mA rating of the leds?
renderblender
« Reply #4 on: September 07, 2003, 10:52:14 PM »
The mA is probably 20 mA, Why don't you download x24's Led Calculator? just search the forums for it, Also here is a good link that will tell you what wattage rating the resistor must be: http://linear1.org/ckts/led.php
Deleted double post
GTF Mod
Page created in 0.057 seconds with 33 queries.
