  • January 19, 2020, 09:11:04 AM
Pages: 1 2 [3]   Go Down
Author Topic: [?] Another quick power supply question  (Read 4415 times)
mphase
    • http://vampirical.com/
« Reply #20 on: September 05, 2003, 05:16:00 PM »
Don't worry about your power suppy handling it, just don't put more than seems resonable on each line.
This may seem inelegant but you may just want to double stuff two pairs of wires into each molex and run the second one to the next connector. I'm not sure what the problems envolved would be but if you did it right it would sure be perty.
keristillax
« Reply #21 on: September 05, 2003, 08:50:46 PM »
alright thanks, and btw for the CCFL im going to have a molex that ill extend the wires for so the inverter will be on one directly from the power supply, i might even build the invertor into the plexi box on it.
chrisbliss18
    • http://www.geocities.com/chrisbliss18@sbcglobal.net
« Reply #22 on: September 05, 2003, 10:15:07 PM »
That's an idea I never thought of. I never considered just lengthening my CC cables. Hmm.... Stuff to think about.
MindHacker
« Reply #23 on: September 06, 2003, 08:58:37 PM »
You could run a second set of cables along the side of the one set if you wanted to make sure you didn't overamp the wires.
Code: [Select]
psu|====_____
='s are doubled (sets of 4) wires, while _'s are one. Hope this helps, MindHacker
256 9600pro,  <|>  none
80gig            <|>  Tera
Pages: 1 2 [3]   Go Up
Page created in 0.055 seconds with 33 queries.
