  • July 23, 2019, 10:27:13 AM
Author Topic: ccfl hdd activity indicator?  (Read 1678 times)
DiddlySquat
« on: September 03, 2003, 05:54:35 PM »
Hey everyone.  I've been googling around for this for awhile now.  Does anyone know where to find a guide for a ccfl that throbs according to hdd activity?  Or does anyone know how to do it?  I saw something similiar one time but i didnt get all the details on how they did it.  :idiot:   Any help would be great. Thanks!
renderblender
« Reply #1 on: September 03, 2003, 06:02:17 PM »
you could hook it up using a relay.
Geet Lord
« Reply #2 on: September 03, 2003, 06:05:02 PM »
x24 told me to use an "optoisolator" (i think) to do the same thing with a series of leds its more or less an optical relay so that the ccfl circut will be isolated from your mobo
« Reply #3 on: September 03, 2003, 07:11:37 PM »
A relay isn't the best (or even a good) way to flash a CCFL.  Solid state is definitely the way to go.  Optoisolator with a darlington output or a FET/MOSFET.
DiddlySquat
« Reply #4 on: September 03, 2003, 07:43:38 PM »
what is a darlington output and a FET/MOSFET?
« Reply #5 on: September 03, 2003, 09:04:19 PM »
An optoisolator uses a LED and a phototransistor to transmit the signal.  The phototransistor usually can't source enough current to run a CCFL inverter, so you use one with a darlington output, where a higher current transistor is activated by the phototransistor.  A FET is a power transistor and a MOSFET is a high power transistor.
Page created in 0.054 seconds with 19 queries.
