  • December 15, 2019, 06:33:16 AM
Author Topic: Fixing an ATX PSU  (Read 2567 times)
BiGReD
Fixing an ATX PSU
« Reply #10 on: September 03, 2003, 04:57:25 PM »
Do you have a load on the power supply?  I have an old atx that if you short the leads to turn it on, it will spin the fan up for about half a second or less (enough time to charge all the capacitors up) then it will stop.  It only spins the fan up again when there is something connected to it.
chrisbliss18
    • http://www.geocities.com/chrisbliss18@sbcglobal.net
Fixing an ATX PSU
« Reply #11 on: September 04, 2003, 02:59:10 AM »
I'd like to say thanks for all the attention on this post. I appreciate it. I do not have a load on any line, not even for a moment. I attached an LED to one of the lines and never saw a flicker out of it. I didn't intend for this PSU to be a test PSU. Since it failed to work, I installed a different one in the system that I built. I'd like to get it working so I can install it in another system that I am planning on building. I just have a hard time understanding how a nice, unmodded 470W PSU can die from something as simple as grounding out the power on lead :wtf: . If the only alternative is to junk it, I suppose that I could just scrap it for parts. Really sad to do that to such a fine unit  :cry: .
DurocShark
    • http://www.donimages.com
Fixing an ATX PSU
« Reply #12 on: September 04, 2003, 08:05:13 AM »
Quote from: BiGReD
Plug in an old CD ROM or something. See if that allows the PSU to power up. (An LED isn't enough of a load for the PSU to notice...)
Fixing an ATX PSU
« Reply #13 on: September 04, 2003, 09:40:11 PM »
Fans work too.
Page created in 0.128 seconds with 19 queries.
