  • June 20, 2019, 12:08:29 PM
Author Topic: Modding Colc Cathode Inverters  (Read 1209 times)
chrisbliss18
    • http://www.geocities.com/chrisbliss18@sbcglobal.net
« on: September 03, 2003, 10:28:09 AM »
I currently have 5 Cold Cathode fans in my case, each of which has an inverter. I also have another inverter for my two UV CCs. I still want to add one more inverter to add two blue CCs, but have yet to do so since there are so many inverters sitting in my case right now. I wanted to know if anyone knew of a way to make a customized inverter that could power all of my CCs. I found that I can usually combine two inverter boards into one box, but that still only helps a bit.
« Reply #1 on: September 03, 2003, 05:39:50 PM »
You'd have to make an oscillator and find a transformer that could step up the voltage to the level that CCFLs take while providing enough current.  Doable, but you'd have a much easier time just getting all the inverters separately.  Maybe you can find a 5 output CCFL inverter.
modnut
« Reply #2 on: September 03, 2003, 05:41:23 PM »
i think they sell multiple cc invertoers, becasue the dual cc's have only one inverter.  just google for it and you mightfind some inverters that can hande more than 2 cc's
Page created in 0.05 seconds with 19 queries.
