  • December 15, 2019, 06:33:25 AM
Author Topic: High level sound to low level sound  (Read 1771 times)
NEO-THE MATRIX
« on: September 03, 2003, 09:38:20 AM »
Anybody know of a simple way of reducing high power sound coming out of a 50w peak amp to a low level input pls?  The circuits that I found are fairly complicated and I do not like the idea of using resistors.  Anyone knows of a "decent" circuit please?
*Celeron D 2.6GHz oced 3.33GHz*
*2x Corsair PC 400 DDR RAM 256MB*
*ABIT IC-7G MOBO*
*GeForce 6600*Internal Sound Mixer*
*SoundBlaster Audigy*SoundBlaster Pro*
Ykarts4u
« Reply #1 on: September 03, 2003, 01:56:53 PM »
Rhinoceruses don't play games. They f*cking charge your ass!
NEO-THE MATRIX
« Reply #2 on: September 03, 2003, 04:41:26 PM »
hmm.. think so but just like the modding scenario it would be nice to have a "modded" converter
*ABIT IC-7G MOBO*
« Reply #3 on: September 03, 2003, 05:41:34 PM »
How about a step down transformer?
NEO-THE MATRIX
« Reply #4 on: September 04, 2003, 01:24:06 AM »
would it be just any step down trans or must it has something special? Also, what must be the winding ratio?  Thanks, I think I might just go with that you idea, thanks viridius
*ABIT IC-7G MOBO*
« Reply #5 on: September 04, 2003, 09:45:25 PM »
Most of the audio transfomers you'll find aren't the highest quality as far as frequency response, but they make 'em in a 5:1 ratio that might work.  They're pretty low power though, so you may have to go with one of the circuits you found.
NEO-THE MATRIX
« Reply #6 on: September 05, 2003, 06:07:47 AM »
Ok, thanks, I will try and see if my local electronics shop suggests something (he usually does), but thanks again
*ABIT IC-7G MOBO*
Page created in 0.793 seconds with 19 queries.
