  • February 27, 2021, 10:24:04 AM
Author Topic: Non-Conductive household materials?  (Read 4512 times)
Merlin_Oak
« Reply #10 on: September 02, 2003, 12:48:27 AM »
Get some antistatic wrist bands - and then never set it down.
fuzzball172
« Reply #11 on: September 02, 2003, 01:48:32 AM »
Use a sheet of foam rubber, you can get it from textile shops, you can get different densities from quite soft to really hard
Squeak
« Reply #12 on: September 02, 2003, 03:44:55 AM »
what about using peices of tubing with bolts?
redfox
« Reply #13 on: September 02, 2003, 06:01:23 AM »
just get a sheet of plastic and lay it in the bottom.
Just like in the bottom of the Dreamcast and some power supplies.
That'll keep everything from touchin.
Good luck!
Ben
wussap!
DurocShark
    • http://www.donimages.com
« Reply #14 on: September 02, 2003, 06:50:47 AM »
Quote from: Squeak
Don't wanna be machining tubes since the bottom is uneven. That was my first thought. Sigh.
Foam rubber sounds like a winnar. :D
Shikasta
« Reply #15 on: September 02, 2003, 07:20:49 AM »
I find newspapers or old computer mags are good, becafull of staples.
MindHacker
« Reply #16 on: September 02, 2003, 04:15:00 PM »
Wood, paneling, Drywall (sheet rock), carpet pieces.  Sounds like fun!
256 9600pro,  <|>  none
80gig            <|>  Tera
fuzzball172
« Reply #17 on: September 03, 2003, 05:57:05 AM »
linolium, floor tiles, ceramic tiles, leaxn, plexi, rubber, rubber car mats
DurocShark
« Reply #18 on: September 03, 2003, 08:18:30 AM »
Quote from: fuzzball172
Lexan and plexi??? Hmmmm..... Ideas....
fuzzball172
« Reply #19 on: September 03, 2003, 10:20:38 AM »
there is a project log over on the bit-tech forums where a guy has made a mobo tray from lexan... maybe worth a look... will try to find the link
Page created in 0.083 seconds with 61 queries.
