  • July 11, 2020, 05:59:17 AM
Author Topic: tbird question....  (Read 5474 times)
otaconx
    • http://otaconx.net
tbird question....
« on: August 20, 2001, 02:43:00 PM »
ok, if ya don't know what happened before:
http://forums.gideontech.com/viewtopic.php?topic=181&forum=12&8
so, i'm at newegg lookin' for a new tbird for myself....
and i find 2 different OEM versions of the 1.4 at slightly different prices, what's the difference between "OEM Version Stepping AYHJA" and the standard OEM version?
also... what heatsink/mobo would you recommend?
tbird question....
« Reply #1 on: August 20, 2001, 04:12:00 PM »
AHJYA is the new overclocking craze...  Apperently you can oc these cpu's really high...
Antacus
tbird question....
« Reply #2 on: August 20, 2001, 04:32:00 PM »
I like the iwill kk266, but there is a whole thread on mobo selection (I think the guy ended up choosing a soyo dragon) thats just recent here.
As for the hsf combo.. avoid the factory one that comes from AMD. I'll let ya know how my new copper GW works after Gideon shipps it out :D
If you can stand the noise the Swifttech is sweet, actually I think all the good hsf's have a ~45ish db level, 7000rpm delta or such. I did not think 45dba was that loud but it is VERY noticable. I can't use the speaker phone when playing with friends anymore.
myr
tbird question....
« Reply #3 on: August 20, 2001, 08:03:00 PM »
well about the mobo.. i started a topic about what mobo to buy.. and i'm still looking for "my mobo" :D i'm thinking on a Asus or a Msi.. but still dunno...
About the HS, well i was looking today for the review of the Swiftech MCX370-0A (i was on vacations and only got home today) and i only think, "I have to get this HS!". :)
otaconx
tbird question....
« Reply #4 on: August 20, 2001, 08:12:00 PM »
thanx =)
now i've just gotta wait for this check to clear from my latest job (they pay me 300 bux to build em a machine... rotfl), and i'll order the ayhja (it's only a few bux more) and the swiftec (i don't mind the noise)...
mobo-wise... i'd love something along the lines of an abit-w/ soft-jumpers, that's sooo sweet. i'll look for that other topic.... mmm, the soyo dragon looks sweet, i think i might get it... i'll wait and see how the other guy does w/ it...
thanx ;)
SnakeEyes
tbird question....
« Reply #5 on: August 21, 2001, 01:22:00 PM »
Good luck with that combo, and IMO great choices so far!
I've got an Asus A7M266 right now, which has been a pretty good board.  Unfortunately Asus/AMD seem to have decided that the ability to change multipliers in the bios will NEVER be an option with this setup, despite preview boards having that feature.  I bought a golden socket adapter instead, hehe!
Anyway, you should have loads of good choices for DDR motherboards at this point (I didn't 4 months ago).  I may end up upgrading again in the next six months, once a Palimino of at least 1.5Ghz unoverclocked has hit the market.  You might want to keep an eye out for reviews of Sis' new DDR chipsets, as well as the nVidia Crush (rumored to be delayed now, but you never know).  Those have great paper specs, at least, even compared to things currently available.
otaconx
tbird question....
« Reply #6 on: August 21, 2001, 06:35:00 PM »
sweet
i just checked out crucial.com...
http://www.crucial.com/store/listparts.asp?model=SY-K7V+Dragon&x=12&y=17
<40 bux for 256mb of DDR ram.... wowie!
now.... the only thing left is to find a suitable hsf or some other method of cooling it....
SnakeEyes
tbird question....
« Reply #7 on: August 22, 2001, 11:22:00 AM »
You meant cooling the processor right?  (sorry, just a little confused after reading another post about RAMsinks).
I can say that the Crucial PC2100 DDR works fine in my case with only my case fans at up to 150Mhz (fsb, x2 for DDR = 300Mhz).  I've actually booted into Windows at 160Mhz, but it wasn't stable at all.  I don't think the instability was the RAM though, more likely my processor just not liking to be at 1.6Ghz very well even at the max voltage the motherboard will let me set (~1.85).  This is supported by the fact that after I installed the golden socket, changed the multiplier, and booted up, I still couldn't hit 1.6Ghz stably, even though my fsb was below 150Mhz (where it was stable using only the fsb settings before).  Right now I'm at 1.533Ghz and stable (other than crashes because of the slowly degrading OS..)
_________________
SnakeEyes[MU]/|WM|Azash
tbird question....
« Reply #8 on: August 22, 2001, 11:33:00 AM »
all I have to say is splurge your money and get the good cas 2 stuff...  else I'll blow your mem bandwidth scores out of the water with my pc166 cas 2. :)
OWNAGE!
:D :D :D
_________________
Tbird 1.4 @1.53
Iwill kk266r (had to hack it for Directx 8 )
512 Megs PC166
Geforce2 GTS 64 Meg
Onboard Sound w00t!
16X DVD
otaconx
tbird question....
« Reply #9 on: August 22, 2001, 01:20:00 PM »
yeh, well, this is what i'm working with now *tear*
http://otaconx.net/images/slowassram.jpg" alt="my slow ass ram">
