  • June 24, 2019, 02:22:33 PM
Author Topic: Key Switch  (Read 2360 times)
Zero Nova
Key Switch
« on: August 31, 2003, 12:32:13 AM »
hey this would work ok for just a normal on/off switch right?
http://www.allelectronics.com/cgi-bin/category.cgi?category=700175&item=KSW-26&type=store
If anyone knows a better one, or even just cooler looking let me know
Key Switch
« Reply #1 on: August 31, 2003, 12:38:07 AM »
If you're not planning on using it as your PC's power/reset switch, it will work fine.
NEO-THE MATRIX
Key Switch
« Reply #2 on: August 31, 2003, 01:20:14 AM »
What are you going to switch on but?
*Celeron D 2.6GHz oced 3.33GHz*
*2x Corsair PC 400 DDR RAM 256MB*
*ABIT IC-7G MOBO*
*GeForce 6600*Internal Sound Mixer*
*SoundBlaster Audigy*SoundBlaster Pro*
hermangarza
Key Switch
« Reply #3 on: August 31, 2003, 09:09:32 AM »
thats the one i was going to get but i didnt know how i was able to connect the leds?
MindHacker
Key Switch
« Reply #4 on: August 31, 2003, 10:11:15 PM »
This is On/Off. It will work with ccfls, fans, and the sort.  It will work on an AT psu if you use a relay.  It will work with ATX (modern) PSUs if you flip the key over and back. I think. Not sure on the last one but it should work.
256 9600pro,  <|>  none
80gig            <|>  Tera
modnut
Key Switch
« Reply #5 on: August 31, 2003, 10:33:00 PM »
if you want a cool switch look here http://www.overboost.com/obs/product.asp?pid=22836
these switches at overboost are awesome.  i want some, but i never got around to buying them
Rcdude7378
Key Switch
« Reply #6 on: August 31, 2003, 10:39:26 PM »
Quote from: modnut
What exactally do you get when you buy that....it says "Ignited Aluminum Engine Start Din Panel , Ignited switches not included" Then it says " Fits 3 Protector Cover Switches and 1 Engine Start Button".
modnut
Key Switch
« Reply #7 on: August 31, 2003, 10:49:52 PM »
sorry, click the "more applications" and there are alot of lighted switches and stuff.
Page created in 0.131 seconds with 19 queries.
