  • June 03, 2020, 05:30:40 AM
Author Topic: ic voltage supply ?  (Read 1939 times)
divideByZero
  • woof
ic voltage supply ?
« on: August 28, 2003, 02:17:10 PM »
do all ics have to be powered even if the schematic doesnt call for it?
daPyr0x
ic voltage supply ?
« Reply #1 on: August 28, 2003, 02:31:28 PM »
there's gotta be some sort of power going to it, I don't know of any ic that doesn't need a steady source of power, but I know some things power themselves off the signal....
divideByZero
  • woof
ic voltage supply ?
« Reply #2 on: August 28, 2003, 03:02:35 PM »
got the answer. they do need their own power if they are designed for it.
ic voltage supply ?
« Reply #3 on: August 28, 2003, 03:42:48 PM »
ICs aren't all the same, there are different families, different number of pins, etc, etc.
What you always have to do is to get the data sheet of the IC and look if they have VDD (+) and VSS (-)
ic voltage supply ?
« Reply #4 on: August 28, 2003, 05:45:28 PM »
Remember that TTL must be powered by 5 volts always.  CMOS can go up to 18 volts.
divideByZero
  • woof
ic voltage supply ?
« Reply #5 on: August 29, 2003, 12:52:58 AM »
i should have said that i got the specs from fairchild semicondutors website. it all worked out.
Page created in 0.051 seconds with 34 queries.
