  • June 07, 2020, 12:39:49 AM
Author Topic: [?] Question on putting on heatsink with artic silver  (Read 2047 times)
TemplaraPheonix
« Reply #10 on: August 29, 2003, 01:27:03 AM »
Quote from: AMD_Junk13
I don't think we are talking about putting on these HS for proformance but for looks. HS on RAM does not help that much if at all. That is why thermal tape is a good way to do it and alot cheaper.
Not true. Sinks help with both Video RAM overclocking around 6%, and system RAM being stable and getting lower timings if not faster Mhz.
However, I agree that those Tt sinks are crap for cooling. You really need individual copper ones. I'm currently in the process of making some out of a HSF, but the Tweakmonster are also okay. Just use the tape, and a dap of epoxy to hold it if the tape doesn't stick well.
keristillax
« Reply #11 on: August 29, 2003, 01:36:03 PM »
alright thanks for the help much appreciated, but where can i get the tape? i cant find it anywhere.
TemplaraPheonix
« Reply #12 on: August 29, 2003, 08:51:25 PM »
Tape should have come with the Tt memory kit. If not, you can buy expensive thermal tape from oline PC shops. You can cheaper, thin (not the 3mm foam) doublestick tap at any office supply store.
keristillax
« Reply #13 on: August 29, 2003, 09:29:15 PM »
tape... would that work, i mean i actually want the heatsink to work.
TemplaraPheonix
« Reply #14 on: August 29, 2003, 11:44:34 PM »
The Tt frag tape really isn't much better. As I said, you can order frag tape online.
http://www.highspeedpc.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HSPC&Product_Code=frag&Category_Code=VCC
However, $12 (you'd probably need 2) and shipping is expensive.
AMD_Junk13
    • Ross Computer Technologies
« Reply #15 on: August 29, 2003, 11:58:56 PM »
$12 for one... don't know how to search well do you? :roll:
$3 for 5  $5 for 10  Here-> http://shop.store.yahoo.com/cybercooler/thermaltape.html
New specs tba...
keristillax
« Reply #16 on: August 31, 2003, 02:10:14 PM »
alright ill order some once i get some money. thanks for all the help.
Page created in 0.25 seconds with 46 queries.
