  • July 20, 2019, 02:50:09 PM
Author Topic: remote  (Read 2936 times)
_Mantis_
    • http://www.lanparty.visiems.lt
remote
« on: August 20, 2003, 10:09:06 AM »
any of u know how to build a radio remote control?
The idea is this:
The alarm clock instead of beeping would start the signal generator and the pc switch would be wired to the reciever so when it hears that signal it turns on.
Also my alarm could start multiple things on that freaquency like my radio,etc.
TokMor
remote
« Reply #1 on: August 20, 2003, 10:12:04 AM »
maby you could get one of thoes remote controll dorbells and hack out the speaker on the alarm clock and put the button on the doorbell across the alarm wires (probably should use some sort of relay to isolate them) then get the the ringing part of the dorrbell to instead of ringing hack out the speaker in that to make a relay to short the power pins on the mb.
remote
« Reply #2 on: August 20, 2003, 08:22:18 PM »
The remote control doorbell is a good idea.  I suggest using transistors instead of relays to reduce back-emf.
daPyr0x
remote
« Reply #3 on: August 21, 2003, 12:57:34 AM »
just...umm....as a quick idea?
most bioses I have worked with had a feature that would turn them on at a certain time....
sure, it aint a mod....but it's hella cheaper and easier.
c0in
remote
« Reply #4 on: August 21, 2003, 01:18:07 AM »
where can i buy remote controlled doorbells :-?
k thnx   :D
_Mantis_
remote
« Reply #5 on: August 21, 2003, 04:49:34 AM »
well one problem i think i said multpile things so it would be best if i knew the schematics. They have to be as minor as possible. Because my seen doorbell rigs ar quite big inside.
DurocShark
    • http://www.donimages.com
remote
« Reply #6 on: August 21, 2003, 01:32:53 PM »
Quote from: c0in
k thnx   :D
Radio Shack has carried them for years... (Firewall blocks RadioShack for me, but you should have no trouble finding them there...)
modnut
remote
« Reply #7 on: August 21, 2003, 01:48:53 PM »
i got one of those remote contol doorbells at the homedepot or osh, but i would just use the bios feture.
Zero Nova
remote
« Reply #8 on: August 25, 2003, 12:29:33 PM »
why go through the trouble of hacking up a door bell,
why not just use something made for what your trying to do
RF Remote
http://www.hobbytron.net/product1416.html
Infrared Remote
http://www.hobbytron.net/product1415.html
TokMor
remote
« Reply #9 on: August 25, 2003, 12:46:38 PM »
because it's more fun to make things do what they weren't meant to do.
Page created in 0.074 seconds with 19 queries.
