  • January 29, 2020, 04:22:18 AM
Author Topic: Anybody use the temp sensor on their Volcano 11+?  (Read 610 times)
donimages
« on: August 19, 2003, 01:44:03 PM »
I've been using the manual controls on this HSF and got it so it never goes over 50c under load. But I like the idea of it changing dynamically...
So who's used the little probe that came with theirs? Is it reliable? And what temps does it use for baseline?
« Reply #1 on: August 19, 2003, 01:55:47 PM »
its very reliable, I think it works great. Go on thermaltake's website, there is a temp to RPM graph.
Im_gumby
« Reply #2 on: August 19, 2003, 02:04:41 PM »
I've used the same probe on the TT9, but I had to strip some of the insulation so that it would fit more flushly.  Works good.
Page created in 0.074 seconds with 32 queries.
