  • October 30, 2020, 01:32:45 PM
Author Topic: Add led to fans?  (Read 2619 times)
Zero Nova
Add led to fans?
« Reply #10 on: August 17, 2003, 09:32:20 AM »
well it depends on what direction you face the led, if its on its side then yes it does
matter. If your drilling 5mm holes and sticking them in there then no because the
surface your gonna hit is almost point blank.
shah
Add led to fans?
« Reply #11 on: August 17, 2003, 09:33:24 AM »
that's what I thought. I am going to be doing the same thing that they did @ ModFathers.
snow veil
Add led to fans?
« Reply #12 on: August 17, 2003, 10:13:44 AM »
also, I'd reccommend the enermax clear fans for the process.  They've got good airflow/noise ratio, and the blades are clear.
TemplaraPheonix
Add led to fans?
« Reply #13 on: August 19, 2003, 01:50:35 AM »
I'm very surprised at how good that mod came out. Maybe it had to do with the fact the fan wasn't clear? Hope yours looks as good.
Havoc_108
Add led to fans?
« Reply #14 on: August 23, 2003, 01:44:31 PM »
Well I made one just by drilling holes and addin led wit resistor
shah
Add led to fans?
« Reply #15 on: August 25, 2003, 10:42:39 AM »
DAMN! I LOVE THIS MODDING!
I got a YS Tech 130cfm Fan and not only that but now it has LED!
The first 120mm 130cfm LED FAN!
so HAPPY! :D :D :D
Pics will be posted soon
renderblender
Add led to fans?
« Reply #16 on: August 25, 2003, 07:55:47 PM »
I just finished with this same project! Here is how it went: I Started with a Clear Fan, then I drilled the hole for 4 3mm Leds, then I super-glued the leds in the holes, then I wired it up.
If you are using a clear fan, you need to sand the fan blades so the Light will not just shine through it.
